body styles
Old Apr 17, 2006 | 09:04 PM
pockets's Avatar
pockets
body styles
I am about to start a ground up restoration on a 65 4x4 short box. I have two short box 4x4 frames but only one 4x4 body. I will eventually build both trucks so the question is, is there much conversion necessary to put a 4x2 body on a 4x4 frame? I would like to start with this truck to use as a daily driver and then begin the 4x4 oringinal as a show truck.
Thanks, Frank.
Old Apr 17, 2006 | 10:54 PM
Sam_Fear's Avatar
Sam_Fear
I'm thinking the 65-66 4x4 is the same body as the 61-64 f100. Hopefully someone else will correct or verify that.
Old Apr 18, 2006 | 12:04 AM
FordBoypete's Avatar
FordBoypete
You're Right the 4x4s in 65 & 66 use the same cab & front body clip as the 61-64 4X2 did. I don't think the bed matters, but I know the cab sure does.
FBp
Old Apr 18, 2006 | 08:02 AM
garbz2's Avatar
garbz2
Remember the only oddball is the 66 F100 4x4 it shares the later 65 66 low floor cab and front clip and 64 on bed.
Garbz
Old Apr 18, 2006 | 05:28 PM
tomsrod's Avatar
tomsrod
The shortbed 4x4 was not available until 1966. The 61-65 and 66 F250 4x4s are often thought to be shortbeds, probably due to the 120 inch wheelbase. They have the 8 foot 57-60 bed.
Old Apr 19, 2006 | 09:45 AM
pockets's Avatar
pockets
Thanks for the info,Tom. I didn't have a vin plate with one of the 4x4 frames. All I knew is that the wheelbase was 120 inches although the 66 4x4 frame had a 5 bolt pattern whereas the other had a heavier suspension and a 8 bolt pattern. I guess i shouldn't assume.
Old Apr 19, 2006 | 10:00 AM
tomsrod's Avatar
tomsrod
The 5 bolt is an F100 and the 8 bolt is an F250. Look for the vin stamped on top of the frame above the right front axle and maybe a second location on top of a crossmember that would be underneath the cab if it were in place. The F100 4x4 frame should be stamped F11******** and the F250 4x4 frame should be stamped F26********. The 4x2 body will work (61 to 64), but you will have to modify the wheel well openings on the bed due to the shorter wheelbase. You may also have to drill new holes in the frame to mount the bed to the frame. If you are using the old 57-60 bed, you won't have to modify the wheelwells.
Old Apr 19, 2006 | 03:41 PM
pockets's Avatar
pockets
Is there any modifications need to put a 65/66 cab and front clip on this frame ?
RangerMercMan
Nov 24, 2016 11:43 PM
Justin Braun
Oct 6, 2016 10:08 AM
bluegoose95401
Dec 8, 2012 08:11 PM
mark63uni
1961 - 1963 F100 Unibody
Dec 20, 2011 01:42 PM
Tepot
Apr 13, 2009 11:51 PM
