Chassis swap anyone ?
Old Oct 20, 2014 | 12:36 PM
eminencefront's Avatar
eminencefront
Do any of you guys have a link, or any information for swapping a 64 cab and bed, onto a 65-66 F250 frame ?
According to some unsubstantiated rumor, innuendo and speculation, I should be able to swap a 64 Cab, onto a 65-66 frame.
The candidate is a 64 SWB F100.
The donor Chassis is a 66 F250 4x4.
Thanks,
-ef-
Old Oct 20, 2014 | 01:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by eminencefront
Do any of you guys have a link, or any information for swapping a 64 cab and bed, onto a 65-66 F250 frame?
The candidate is a 64 SWB F100. The donor Chassis is a 66 F250 4x4.
1966 F250 4WD uses the same cab you have now. However the 4WD cab may have the cab supports in a different location on the frame.
Cab step, visible when the doors are opened:
1961/64 F100/1100 - 1965 F100/250 4WD - 1965/66 F350/1100 - 1966 F250 4WD
No cab step: 1965/66 F100/250 2WD & 1966 F100 4WD
1957/60 Styleside beds were also installed on the following 1961/66's. Called the "wrong" beds, because the cab lines don't match the bed lines.
1961/65 F100/250 4WD - 1961/66 F350 - 1962/63 F100/250 2WD - 1966 F250 4WD
1964/66 F100/250 2WD & 1966 F100 4WD use different Styleside beds...that match the cab lines.
Old Oct 20, 2014 | 02:05 PM
eminencefront
Thanks Bill,
So if I read that correctly, a 64 F100 4x and a 1966 F250 4x would be a bolt-on upgrade chassis for my 64 SWB ?
The end game, is that my Cab and bed. glass, doors, hood, doghouse are ALL in fantastic shape and in primer. But I really would prefer an updated suspension, and it's a lot more work on a 64 chassis, than on a 65/66 TIB chassis. (or at least, the options are more plentiful.)
Of course it's all work, but all things considered it's a pretty big upgrade up to a 65/66 chassis.
Old Oct 20, 2014 | 02:17 PM
NumberDummy
I know the cab is the same, but what I'm not sure of is the location of the '66 F250 4WD's frame mounted cab supports. They may be the same as 1964 F100 2WD, may not be.
Dave (garbz2) will know for sure.
But you're not getting a better suspension upgrade by using this '66 F250 4WD's frame, as it has leaf spring front suspension just like 1961/64's have.
Twin-I-Beam coil spring front suspension introduced in 1965 F100/250 2WD.
F100/250: All 1961/64 F100/250 2WD's have front leaf springs, as do 1961/65 F100 4WD's & 1961/79 F250 4WD's.
Old Oct 20, 2014 | 02:28 PM
eminencefront
Gah.
I might be stuck with the solid axle then. I'd really like to modernize the front end without butchering it, since the truck is 100% original. I'd like to keep it stock'ish or resto'mod.
decisions decisions. There sure are a ton of CV P.I. in the yard by my house tho.
Old Oct 20, 2014 | 02:48 PM
NumberDummy
Gah.
I just remembered something else that will throw a monkey wrench into your frame swap plan.
1964 F100 6 1/2' short bed has a 114" wheelbase / 1966 F250 4WD's were only available with an 8' Flareside or "wrong" Styleside beds, so its wheelbase is a different length (longer) than your '64 F100.
jas88
Feb 20, 2017 01:47 PM
hoss73ford
May 16, 2016 10:13 AM
Ruffasacob
Mar 28, 2016 11:18 AM
tedrowtr13
May 17, 2015 09:37 AM
FordF100man
Sep 22, 2014 12:46 AM
