it was working, for two weeks. then my truck died on the road on Monday. I thought it was the ICM, I replaced the ICM, truck started drove for 100 feet then died again. the ICM blow up again. have spark, fuel presser.
If you have spark the ICM is working. The ICM makes the Ignition Coil Fire.
This is the truth. Check. If. Your. Injectors. Are. Pulsating. If. So. Then. they. are. receiving. a. signal. from. the. e. e. c. indicating. that. it. is. in. proper. working. order.
You can test pin #60 by shorting Pin #2 to pin #6 of the self-test plug and turning on the key.
If the fuel pumps run then pin #60 has a good ground at the NEG post of the battery or at the body ground depending on the year of the truck.
