Remote start/alarm/keyless entry..
Hey guys. I've seen a lot of questions regarding remote starters and which ones are for diesels. Well my wife had one installed in my truck for Christmas and I thought I would share in case anyone searched in the future. It's an Avital 5303 remote start/alarm/keyless entry. It has a programmable "wait to start delay",mine was set for a 30 seconds, it has a programmable run time, it also has a turbo timer. It comes with the standard remote as well as an LCD two way remote, and a shock sensor. Again I just thought I would put this info out there for future reference.
http://www.avital.com/products/product.aspx?id=5000
Hey guys. I've seen a lot of questions regarding remote starters and which ones are for diesels. Well my wife had one installed in my truck for Christmas and I thought I would share in case anyone searched in the future. It's an Avital 5303 remote start/alarm/keyless entry. It has a programmable "wait to start delay",mine was set for a 30 seconds, it has a programmable run time, it also has a turbo timer. It comes with the standard remote as well as an LCD two way remote, and a shock sensor. Again I just thought I would put this info out there for future reference. http://www.avital.com/products/product.aspx?id=5000
Can you program the WTS setting for longer?
I live in Alaska and when it is zero degrees out and my truck is not plugged in 30 seconds isn't going to be long enough on the glow plugs without a very rough start.
Hell it was 18* this morning, I let the glow plugs run until my LED turned off, cranked for several seconds. Gave the glow plugs another 30 seconds and then it fired up normally.
Can you program the WTS setting for longer? I live in Alaska and when it is zero degrees out and my truck is not plugged in 30 seconds isn't going to be long enough on the glow plugs without a very rough start. Hell it was 18* this morning, I let the glow plugs run until my LED turned off, cranked for several seconds. Gave the glow plugs another 30 seconds and then it fired up normally.
It doesn't seem too many people realize this but pretty much all remote starters will work with a diesel. I've been installing for about 8 years now & I haven't seen a brand yet that won't. Of all the ones I've installed my personal favorate is a brand called Autopage. Good quality, lots of features & the best range I have seen yet.
Mine is a skytech ( sp?) It has worked well for several years. Long range I have the 2 way LCD remote.
nickt916
11-02-2012 06:53 PM
