1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
H9 Axle code - Both 8.8 and 9.75?
Old 12-28-2013, 04:05 PM
Turbocapri's Avatar
Turbocapri
Turbocapri is offline
Hi Guys,
I just bought a 98 Expedition with a bad rear axle. The carrier bearings failed and it's pretty messed up.
The door axle code is H9. The tag on the axle identifies it as an 8.8" 3.55 ratio locking rear.
I've found a 2001 Expedition in a local PIY yard that also has the H9 axle code on the door sticker. However, the tag on the rear identifies it as a 9.75" 3.55 ratio locker.
If I pull the rear out of the 2001 I can get it for $100.
So, is there any reason I can't put a 9.75" rear in the truck? Any other parts I should get? Perhaps the driveshaft from the 2001?
Thanks.
Old 12-28-2013, 07:25 PM
Turbocapri's Avatar
Turbocapri
Some answers to my own questions from searching.
There are 2 issues, one real and one potential.
Beginning in 2000 the wheel stud size increased to 14 mm from 12 mm. That provokes interference with the rotors and the wheels. I suppose I could put a set of axles from a pre 2000 9.75 in.
The other issue is driveshaft length. Apparently the 9.75 is about 1" longer than the 8.8. However, I've seen posts that say this is and isn't a problem. Anyone know?
Old 12-29-2013, 06:14 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
It isn't going to be a good deal if it doesn't fit.
Old 12-29-2013, 06:57 AM
Turbocapri's Avatar
Turbocapri
Yes, at this point I'm inclined to rebuild the 8.8. It's out of the truck and will be up on a bench in the garage later today.
I really don't want the hassles of having 12 mm studs on the front wheels and 14 mm studs on the rear.
abrarham
03-13-2013 05:26 AM
mdacton
07-14-2010 02:21 PM
tommythomasson
11-14-2007 12:10 PM
crg
03-03-2007 03:24 AM
DRP
1997 - 2003 F150
02-05-2004 11:31 AM
Quick Reply: H9 Axle code - Both 8.8 and 9.75?
