Alxe tag help
Old Mar 11, 2013 | 01:26 PM
abrarham's Avatar
abrarham
Alxe tag help
My axle tag reads (3.55 10 2 5L05) but my door tag say axle code 39?
So do I have a 8.8 open diff? I was expecting the axle tag to read something like 3.55 8.8 blah blah.
Any input would be appreciated.
Thanks
Old Mar 11, 2013 | 05:01 PM
Franklin2's Avatar
Franklin2
Axle code 39 is a 3.55 and your tag reads 3.55. If you have a rear cover with bolts, you do have a 8.8 rear.
Old Mar 11, 2013 | 05:17 PM
ctubutis's Avatar
ctubutis
Here is what the parts catalog says for 39 on the Certification Label:
https://www.ford-trucks.com/forums/1...l#post11225573
Here is the information on the axle tags:
Old Mar 11, 2013 | 11:58 PM
bruno2's Avatar
bruno2
Yep, 3.55 open diff. It could be either the 8.8 or 9".
Old Mar 12, 2013 | 05:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by abrarham
My axle tag reads (3.55 10 25 L05) but my door tag say axle code 39?
No.
By posting this rear axle ID tag code, you answered your own question. If it was an 8.8, the tag wouldn't have 10 25 stamped on it.
Sterling 10.25" Rear Axle / 3.55-1 / L05 = Assembled November (L) 1985 (05).
39 = Sterling 10.25" Rear Axle / 3.55-1 / No Limited Slip / 6,250 lbs. Rear Axle Capacity.
1959 thru today: If the AXLE code stamped on the Warranty Plate (1959/79), printed on the Certification Label (1980/) begins with a letter: Limited Slip.
If the AXLE code begins with a number: No Limited Slip.
bruno2: OP's "About Me" profile says: 1986 F250. No F250 came with a 9 inch. And, as you can see, it's not an 8.8 either.
Old Mar 12, 2013 | 08:35 PM
bruno2's Avatar
bruno2
Thanks
Let us know if it is a 3/4 or 1 ton also . Everyone assumed it was a 1/2 ton. They have 9" and 8.8's in them. The 3/4's have sterling 10.25 or Dana 60's. Good thing number dummy chimed in.
Old Mar 13, 2013 | 12:12 AM
abrarham's Avatar
abrarham
Yep its a 86 f250 bb 460 c6 auto so im guess 3/4 ?
sorry noob <<<<----
Old Mar 13, 2013 | 05:26 AM
NumberDummy
Originally Posted by bruno2
Let us know if it is a 3/4 or 1 ton (F350) also. Everyone assumed it was a 1/2 ton. They have 9" and 8.8's in them.
The 3/4's (F250's) have Sterling 10.25 or Dana 60's. Good thing NumberDummy chimed in.
NumberDummy chiming in again.
1983/89 "Light Duty" F250's came with (believe it or not) 8.8's, but the OP's truck isn't a "Light Duty" since the ID tag has 10 25 stamped on it.
Some 1980/86 F250 'Heavy Duty's' also came with Dana 61's. FoMoCo confusion: Never referred to F250's as light or heavy duty's, except in the parts catalog.
8.8 introduced in 1983, but some 1983/86 F100/150's & Bronco's came with 9's, as it depended on the applications.
OldRedRig
1997 - 2003 F150
Jul 31, 2015 08:24 AM
tfs2403
Jan 18, 2011 09:25 PM
mdacton
Jul 14, 2010 02:21 PM
tommythomasson
Nov 14, 2007 12:10 PM
warrencowboy05
Dec 2, 2004 12:34 PM
