Will a 15x8 rim fit on an F250?
Old 12-28-2013, 03:58 PM
Pheadrus's Avatar
Pheadrus
Pheadrus is offline
I know stock I have 16x6's but a guy has a set of nice BFG MT 31x10.5x15 for sale locally for a good price. Can I put a 15" rim on an 89 F250? If yes, what rim size would I need for these tires including backspacing? I'll probably just buy a set of steel 15x8 white wagon style rims for cheap if I can use the 15" rims.
Old 12-28-2013, 04:52 PM
bashby's Avatar
bashby
bashby is offline
I don't think anyone makes a 8 lug 15" wheel. It wouldn't clear the caliper unless it was spaced way out.
Old 12-28-2013, 08:51 PM
Pheadrus's Avatar
Pheadrus
Pheadrus is offline
I thought maybe the older 70's F250 would.
Old 12-28-2013, 09:19 PM
randomguy's Avatar
randomguy
randomguy is offline
They make 8 on 6.5 15" wheels but I doubt you'll get them to fit over the Ford twin piston calipers and big rotors. I know they'll fit on a GM if you grind the calipers, but the GM caliper is the same between the 1/2 ton and 3/4 ton applications, just the rotor is different. Our brakes are way better than what game on the 73-91 GM's
Old 12-28-2013, 10:16 PM
Pheadrus's Avatar
Pheadrus
Pheadrus is offline
Looks like I'll just have to find some decent 16" tires.
Coleton_henry
05-28-2017 08:38 PM
Chris Haynes
10-14-2015 09:29 PM
DeanBob
01-16-2011 03:32 PM
bkohne1
05-02-2010 02:46 PM
fulltimehiboy
01-14-2007 07:12 AM
Quick Reply: Will a 15x8 rim fit on an F250?
