fuel cut off switch
Received 3,992 Likes
on
In the '96 service manual, it says it's on the right cowl panel just forward of the door below the instrument panel. I'm assuming your '95 is in the same place, but do not know for sure.
edit: I found this on another website. This guy's pictures and albums have helped me immensely:
http://www.supermotors.net/registry/media/767953
Yeah, just go in the passenger door and look down by the floorboards to the right. See that trim panel? Look at the top edge of it and you'll find a notch in in... behind it is where the red pushbutton switch is.
If you still can't find it then just take the panel off. You won't miss it then.
SubFord - off this topic, but I am interested in installing roof marker lights on my truck and the book says the wiring harness from the lights plugs into one of these plugs shown in your picture, I believe. Do you know which one of these plugs accepts the wiring harness coming from the lights?
C201 is a two terminal gray plug.
So it should be the top plug in the photo with nothing plugged into it.
The wire colors are brown and black.
The brown wire is from the headlight switch and the black one is ground.
e1p1
03-11-2008 04:49 PM
tigercoool
08-28-2003 09:11 PM
