Turn Signal Canceling ?
Hey Guys, One of the things i would like to get fixed on my 77 Super Cab
is the Turn signal Switch, It works fine but doesn't cancel after the Turn.
easy fix? and any suggestion were to buy the parts?
It has the stock Column and Four speed, not automatic, if that Helps!
I would like to change the steering wheel out too for a aftermarket one also
than that of the stock steering wheel it has now (The stock wheel is missing the center portion for the Horn Assy.)
Thanks for any advice!
Allen
Allen
More than likely the little plastic "arms" that cancel the switch have broken, this is a common problem.
Ford doesn't sell the parts of the switch separately, you have to buy the complete switch, however, Dorman Products does sell a repair kit to fix it. It's part of their "Help" line. The part number is 49301. Rock Auto has them for $11.50.
First though, do like fmc400 said, do some troubleshooting. Make sure that's the problem.
toofazt
09-22-2012 05:48 PM
86fn150
02-09-2008 11:54 AM
