98 f150 shut down/no start
Old 12-12-2013, 07:35 PM
Tex1986's Avatar
Tex1986
Tex1986 is offline
Gentlemen,
I have a serious issue and need help. Vehicle is stranded on the side of the road (safely) and here's what happened. Driving (normal) 1/4 mile away from the house, motor shut down. Pulled off, tried restart. Motor turns over normally and all gauges work (temp/oil/volt). The only weird thing is that the O/D light on the end of the shift selector stays on even after pushing it on and off. I plugged in my OBDII reader and it will not link with the system. Yes... the ignition is on Is this indicative of a fuel, computer, electrical issue? or all the above. Worst case scenario is i have it towed to the shop tomorrow and they diag it. I don't have the proper tools to diag this Thanks for the help all!
Tex1986
Old 12-12-2013, 07:39 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
First , check all your fuses . A no communication error can be as simple as a blown fuse !
Old 12-12-2013, 07:43 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Then Check for fuel pressure and spark .
Old 12-12-2013, 07:44 PM
Tex1986's Avatar
Tex1986
Tex1986 is offline
Thanks, I will recheck all the fuses. After pulling off, i popped the Schroeder valve and the fuel just bubbled up. it wasn't a spray like under pressure.
Old 12-12-2013, 07:50 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Best of luck ! You should have pressure not " bubbles " Keep us posted .
Old 12-12-2013, 07:54 PM
Tex1986's Avatar
Tex1986
Tex1986 is offline
I have NO idea what happened, but my roomate took me back to the truck, it started right up, no issues and no OD light. Will update if any other issues arise. Thanks for the quick reply!
Old 12-12-2013, 08:07 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Hope you find out what the issue was ! Glad you got it going !!
Old 12-13-2013, 09:13 AM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
bubbles was lack of fuel. EIther you have a fuel pump problem that causes pump to quite now and then, or you had a slug of water / ice in the line that changed / melted overnight. If it happens again, or even daily test... when you turn the key every morning, do you hear the fuel pump run for a second and build up pressure ?
Old 12-13-2013, 10:54 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Swap out the PCM Relay with a new one.
Your symptom can be caused by that relay getting intermittent (as well as other things...)
Old 12-13-2013, 11:06 AM
Tex1986's Avatar
Tex1986
Tex1986 is offline
This would be the first time it's ever done this. I live in Tampa FL, so there's no ice. At least from weather conditions. Yes, I do hear the pump run. I went for a drive this morning and it drove fine and no issues. The thing that bothers me is that when the truck shut off, the OD light came on and stayed on.
Jaysun19
2009 - 2014 F150
08-27-2017 06:13 PM
tubby12729
09-04-2012 09:41 PM
leadfoot7
08-23-2012 03:49 PM
firef150
1997 - 2003 F150
01-27-2008 06:28 PM
mnf150
06-27-2002 05:25 PM
Quick Reply: 98 f150 shut down/no start
