brake switch "B" circuit DTC fix? [it constantly disables the cruise control]
does anyone know if this is a fuse ?does pulling the ravelco hub trigger this ? I'll clear the code and then it shows up again day's later.someone mentioned a fix for this awhile back and i shined it on ,now i'm sick of it .My banks six gun diagnostic app is where it shows up not the check engine light? I mentioned the ravelco anti-theft pin- hub cause that throws the fuel pump circuit every time but not the "B" circuit brake switch,I don't pull the ravelco all the time and I never remember that being a trigger.
I have an intermittent cruise control. Some days it works, other days it doesn't. Sometimes after restarting it flips the other way (works or doesn't work). Would this behaviour be related to that switch you mentioned? My Ford mechanics don't seem to want to diagnose. They just return the truck and say it worked for them today.
QUOTE=ArnieBarney;13833180]I have an intermittent cruise control. Some days it works, other days it doesn't. Sometimes after restarting it flips the other way (works or doesn't work). Would this behaviour be related to that switch you mentioned? My Ford mechanics don't seem to want to diagnose. They just return the truck and say it worked for them today.[/QUOTE]
Yes this is what my truck was doing. Pressure switch on master cylinder(front one of two) fixed problem.
Pipeliner_86
12-03-2015 07:01 AM
