I'm about sick of my white smoke during exhaust cleaning...
Well I fumigated the hwy a few days ago. I thought that the re-program a few years back was suppose to take care of the white smoke..once I had mine done I would see very little white smoke when in cleaning mode..now 6 years later, it smoked yesterday worse than it has ever had. weather was cold out and I have been driving short trips lately..30k on truck now...does anyone think there is a problem again or do we all just live with the fumigation unless we do the DPF delete..love my truck but its pretty embarrassing when it happens...bad *** truck smoking down the road like its gonna blow up...I have not noticed the 6.7 doing this, do they?
DO you have the latest PCM flash? Does the smoke have a strong eye watering odor? (indicating unburnt fuel) Another issue is humidity and rain which i have posted a TSB: related to that
TSB
08-25-1
6.4L DIESEL - WHITE SMOKE IN DAMP WEATHER CONDITIONS WHEN ACCELERATING - VEHICLES BUILT BEFORE 10/1/2008
[************]Publication Date: November 26, 2008[/color]
FORD:
2008-2009 F-Super Duty
ISSUE:
Some 2008-2009 F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engine and built before 10/1/2008 may exhibit significant amounts of white smoke from the exhaust pipe while driving in high humidity or rainy conditions at temperatures above 40 °F (4 °C). This smoke only appears during a moderate to full throttle tip-in that is performed after a period of steady state driving.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
This procedure only applies if the vehicle meets the following criteria:
Concern is described as significant amounts of white smoke from the exhaust pipe.
White smoke only occurs in high humidity or rainy conditions above 40 °F (4 °C).
White smoke only appears during a moderate to heavy tip-in that is performed after a period of steady state driving (approximately 20 minutes)
No diagnostic trouble codes (DTCs) are present.
Concern is not a result of regeneration, a cleaning exhaust filter event.
If all of the criteria above is true, then replace the Charge Air Cooler Assembly with a new revised part per Workshop Manual, Section 303-12.
PART NUMBER PART NAME
7C3Z-6K775-B Charge Air Cooler Assembly
__________________
Yes I think I have the most recent PCM flash...it was not humid out but pretty cold...it only happens during regeneration, cleaning exhaust...prior to the re-flash it smoked all the time during re-gen..after new flash all was ok.. But yesterday it was like I had my original flash back cause it was tons of white smoke...
mjnoakes
12-16-2003 02:36 PM
