RSK with OBS Springs
Just doing some reading and pondering while waiting on parts.
Would a RSK still using the OBS springs improve the ride enough to warrant the cost and work?
I like the SD spring claims as far as ride and the look of a lifted OBS but I don't want a lift on my truck. Probably will be doing Bilstein 4600s and rear spring/shackle bushings with the tax return and just want to know if I should be thinking RSK at the same time.
I just did the rsk with my obs springs on my truck so take a look at that part of my build thread. I thought it was a fairly simple job. The ride is not dramatically better, but it is good. I think I am going to flip the hangers in the back to get a little lift there as it rides a little nose up right now. (see pic in build thread)
I have had RSKs with OBS springs
RSKs with Lift OBS springs
RSKs with Stock SD springs
and RSKs with lIfted SD springs
The best ride I found was the RSK with U-code SD springs
next up was a RSK with 4" OBS springs
Unless your OBS springs are brand new, go ahead and go with the RSK for the SD springs and get new springs.
Also, no matter what RSK design you go with, you will be seeing a minimum of 2.25" lift
But if i had to do it again I would definitely do it. But I really wanted some increased height too.
I am happy with mine. i have had it for over a year now and am happy still.i have bilstein 5125s.i retained the front sway bar and did need a pittman arm drop.
the rsk improves the jolt felt in your spine when hitting bumps. the ride is still stiff as the springs are still stockers. i just could not swing sd springs.gabe has the sd springs but the time i rode in it there was a bobcat on a trailer following us...
That is what I have in my CCLB and it rides AWESOME. I have the same setup but V codes in my CCSB and there is a TREMENDOUS ride difference(don't get me wrong, it is 16" shorter and a dually) I am planning on swapping out the V codes in favor of some U codes.
My CCLB w 325/65/18s(34.8x13.50)
Jim40216
10-03-2016 01:23 PM
SVTDarin
01-07-2015 08:30 PM
Barkin 40s
04-08-2011 05:25 PM
