Offroad & 4x4
Front leaf springs....
Old Mar 7, 2007 | 09:24 AM
classicfordfreak's Avatar
classicfordfreak
Hopefully you guys can give me some opinions and insight here. I've got a 90 F-150 that i converted to leaf springs and a straight axle dana 44HD up front. They came from a 78 F-250. Well of course with ford leaf springs, they are sagging pretty good now. The truck had a L6 in it and i have pulled it out and put a 390 in it. With the straight six the springs were sagging significantly and now with the big block they are worse. My question is, would you guys recommend putting new springs in it or maybe just putting an ad-a-leaf kit in it. The truck has a 3" body lift and by the time i got done with the axle swap it sits about 5 to 6 inches taller than stock and i don't really want to lift it anymore than it is now. Any opinions are greatly appreciated. Also, if you recommend new springs, what is a good way to go as far as aftermarket or replacement, or just having some springs custom made. Money is obviously an option. Enough said, thanks, matt
Old Mar 7, 2007 | 10:18 AM
todder53's Avatar
todder53
If you're looking for a short term fix go with the add-a-leafs but i would just get new springs all together. Then you don't have anything to worry about down the road. Don't have any custom made looking at too much money. JC Whitney has replacements front springs for $100.
Old Mar 7, 2007 | 11:16 AM
rebocardo's Avatar
rebocardo
Skip the add a leaf. Get new springs or even springs from a junkyard. Myself, I would go to a local truck/spring shop if you live near an urban area and have custom new springs made. You want a lot of leaves in the front with flex, otherwise the ride will be harsh and brutal on the steering components. Basically, get more lift from more springs (1/4" x # of springs) and counter that with a lower rate springs. Then counter the soft ride with better/dual shocks.
Since the eye to eye length is so short on front springs, you really do not want only 3-4 springs or an overload spring to achieve the lift because it will be a harsh ride.
For front springs, military wrap is never a bad idea.
I have seen charts for this somewhere ... and basically did not understand it, spring guy will though
FE 390 into a 1990, you're the man!!! :-)
Old Mar 7, 2007 | 11:48 AM
classicfordfreak
I already have dual shocks up front. What i would like is too fix the sagging problem. The truck is used for pulling a trailer around home and mild offroad use. I have a set of 4 inch lift springs off a high boy that would bolt right on it but i don't really want to lift it anymore than it already is. So i would like to either fix what i have or buy new.
Old Mar 7, 2007 | 02:57 PM
BUZZer67's Avatar
BUZZer67
I was reading an article in a mag (I think it was petersons) about some fiberglass springs...
Now that was on a jeep but maybe they have some for a F-150
it may be worth a shot to look into
.02
Old Mar 7, 2007 | 06:43 PM
classicfordfreak
First off, the truck has a big block and i need the springs for the front, Second, Fiberglass? I did read that article and it doesn't sound that bad for something small like a jeep as you said. I wouldn't really feel too safe with them in a full size pickup, especially while holding a big block and pulling a car-hauler around all the time. Thanks for the insight though, greatly appreciated.
Old Mar 7, 2007 | 08:31 PM
chrono4's Avatar
chrono4
'vettes have used fiberglass springs, but I dont know whether id trust them on a truck.
Old Mar 8, 2007 | 07:16 AM
classicfordfreak
I agree with ya chrono4. I just want something that will cure the problem somewhat long term wise. I am just skeptical about buying new springs if i'm going to end up with the same problem. I guess my opinion is that if i buy new replacement springs with only the two leaves again, it will end up sagging just like the originals, whereas if i added a leaf or possibly bought new springs and addaleafs, or just had some custom made with more springs i would be able to solve the problem more long term. I'm not worried about a rough ride, after all thats what a truck is supposed to be like right?
Old Mar 8, 2007 | 08:12 PM
chrono4's Avatar
chrono4
What about adapting some rear leafs minus some leafs for the front?
SuperDutyScaler
Jan 18, 2011 08:58 AM
hatchet
Offroad & 4x4
Dec 3, 2006 01:17 PM
BigBlockF-250
Offroad & 4x4
Apr 2, 2005 09:39 PM
RawPower
Aug 28, 2003 08:42 PM
