1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
transfer case chain slap
Old 11-17-2013, 08:31 PM
pcpierce's Avatar
pcpierce
pcpierce is offline
I hear a distinct chain slap coming from my transfer case-- I have a 1999 Ford F250 Crew cab SD with a 5.4, manual transmission. Is that slap sound normal? I have only 160k on the vehicle
Old 11-18-2013, 05:24 AM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
Have you ever services the transfer case?
When you hear this noise are you in 4wd at the time? Some noise is considered normal but every little.
Old 11-18-2013, 09:57 AM
SteveH-CO's Avatar
SteveH-CO
SteveH-CO is offline
No - not normal. I would jack it up and check the play in the input/output shafts of the xfer case in high and low, 2 and 4WD. If you drive it long with it slapping, you may incur much higher repair costs.
Old 11-18-2013, 10:21 AM
pcpierce's Avatar
pcpierce
pcpierce is offline
had to drop the clutch out to replace pilot bearing and will likely have the t-case checked out. The sound comes in both 2wd and 4wd. Thanks for the input. I didn't think it was normal, and will get it checked
strat875
02-25-2023 08:30 PM
Scarob63
2017+ Super Duty
18
12-13-2017 07:21 PM
Rockhill
02-09-2010 04:33 PM
lestro
01-17-2010 09:48 PM
Sf006
1978 - 1996 Big Bronco
08-29-2005 11:57 AM
Quick Reply: transfer case chain slap
