Sponsored by: Real Truck
Four wheel drive not engaging
Old Nov 18, 2013 | 11:06 AM
ontariofarmer's Avatar
ontariofarmer
We went to a friends cottage last night, and their lane is very steep. While we were there it poured rain for about half an hour. I needed to get out in 4 wheel so I turned the switch on the dash.....I could hear some noise under the truck but it didn't engage. I finally had to go out and manually engage it and up the lane we went.
It worked fine last week when I needed to get around in the snow.
Any ideas on what I should look at?
Old Nov 18, 2013 | 11:22 AM
EXv10's Avatar
EXv10
The switch on the T-case or a seal leak up front, do a search on in it here, lots to read.
Old Nov 18, 2013 | 11:27 AM
Bigpipes 35's Avatar
Bigpipes 35
If the system worked when you manually locked the hubs then your looking at a vacuum issue, either a broken vacuum line going to one of the hubs or a bad vacuum seal or bad hub. You can get a gauge and apply vacuum to each hub individually to determine if its the hub or seal and isolate which side of the truck..
RV_Tech
24
Nov 3, 2016 07:35 PM
sledgehammer100
Apr 22, 2012 09:40 AM
yotazuki
Jul 14, 2009 10:29 AM
Reckless
41
Mar 4, 2009 08:06 PM
iyak
Dec 11, 2006 11:16 PM
