Help with CEL codes
Out of all the codes you listed, the only one I have personal experience with is the P0460.what it boils down to is his fuel level float in the fuel tank is sticking. It is more than likely caused from corrosion. Have your son in law remove his gas cap and wrap a clean white rag around his finger. Then. Wipe the inside of the fill pipe to see if it comes out rusty. The good news is the gas tanks are plastic and the only parts effected are the fill pipe and the fuel sender slider rod.to correct the situation he can either replace the fuel sender for around $500 or he can do the following.
At each fill up add a mixture of one cup DieselKleen and one cup of Ashless 2 Stroke Motor Oil. Not only will this mixture quiet down and lube his Injectors but it will also lube the slider rod in the tank. Since using this in my truck my P0460 hasn't come back for two years. Hopefully someone else can help with the other codes.
dieselKleen (Gray bottle) and 2 stroke oil can be found at WalMart
gesb123
1999 to 2016 Super Duty
10-29-2014 08:46 AM
