driving me crazy
Old 11-02-2013, 08:35 PM
lilrobo's Avatar
lilrobo
lilrobo is offline
I will double check the return line, mybe add another clamp,, something got to be wrong, , wrong size pully, pump not big enough,, gear box clogged, , or something? ?..
Thanks
Old 11-02-2013, 08:40 PM
seaves46's Avatar
seaves46
seaves46 is offline
Check for leaks when holding the steering wheel at full lock for short periods .
That's when they are more likely to leak .
Old 11-02-2013, 08:48 PM
lilrobo's Avatar
lilrobo
lilrobo is offline
Thanks will do
Old 11-03-2013, 08:11 AM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
without being able to hear it I would speculate that it's pump cavitation . Sticking pressure relief valve , restriction in the system and excessive pump speed can all be causes of this .
Old 11-03-2013, 12:32 PM
lilrobo's Avatar
lilrobo
lilrobo is offline
its the second pump i put on ,, maybe another bad pump ,, i dont know if its the right pump for the toyota gear box ??
Old 11-04-2013, 10:58 AM
lilrobo's Avatar
lilrobo
lilrobo is offline
could it be the fluid is getting hot ,, should i use AFT ??
Old 11-04-2013, 05:35 PM
lilrobo's Avatar
lilrobo
lilrobo is offline
over at a toyota forums they said that the toyots's boxes take AFT maybe thats it ,, the fluid is getting hot ??
i'll see i will change the fluid
Old 11-04-2013, 06:55 PM
Branded's Avatar
Branded
Branded is offline
What's AFT?
Old 11-04-2013, 07:05 PM
lilrobo's Avatar
lilrobo
lilrobo is offline
Sorry ATF
Swamp Truck
12-31-2017 05:27 PM
Greg9321
06-21-2017 09:40 PM
jwcopeland
12-31-2014 09:57 AM
bomberboat
10-31-2008 10:28 AM
blockheadbob
11-14-2007 07:57 PM
Quick Reply: driving me crazy
