5 spd mazda speedo
Old 10-30-2013, 12:24 PM
whereiskrazydave's Avatar
whereiskrazydave
whereiskrazydave is offline
5 spd mazda speedo
I have a '95 5spd with electronic speedo.
The tail housing has the place for the mechanical speedo, but not machined out.
what my question is does the output shaft have the gear on it?
If it does then I can machine out the tailhousing
I do have a '89 5spd and it has the M-speedo but I'm trying to save that one for my van. any help would be appreciated.
"my dad was a T.V. repairman he has an awesome set of tools he can fix anything"
Old 10-30-2013, 12:26 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I would bet there is nothing in there to run a gear speedo
Old 10-30-2013, 01:12 PM
77 1/2 F250's Avatar
77 1/2 F250
77 1/2 F250 is offline
If you are lucky, the tailshaft will be machined for the gear. I had to go through this when I put a transfer case from a 93 into my 88.
The easiest way would be to use an older tailshaft housing that is already machined for the speedometer cable.
Robert
Old 10-30-2013, 06:39 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
2X
I have the same problem with a E4OD going(possably) into my 89 F250. It has the machined place for a speedo cable(plugged off), but no gear on the tail shaft
CWPottenger
11-23-2010 05:04 AM
myklstrng
10-22-2010 10:00 PM
AndysFords
07-20-2006 09:33 PM
wment
02-11-2006 09:39 PM
Frdbuy8589
08-25-2003 07:24 PM
Quick Reply: 5 spd mazda speedo
