Speedo reading too fast
Old Feb 11, 2006 | 06:56 PM
wment's Avatar
wment
I have just installed 4:11 gears behing my 302 with a C6. The speedo reads about 60mph when Im going about 40mph. According to the old parts books I have, the proper speedo gear is installed but I need a reducer/adapter to reduce the speed of the cable by about 70% (actually .695 to 1). I have looked all over, can anyone point me in the right direction to locate one.
Wayne
Old Feb 11, 2006 | 09:10 PM
rclarke's Avatar
rclarke
A C6 has the drive gear rolled onto the output shaft and there are 2 different shafts, 7 tooth and 8 tooth. You may have to change the output shaft to get the speedo to read correctly. If you can find a good speedo shop it is possible to have a gearbox made to add into the speedometer cable to fix the problem.
If you have a 4x4 the drive gear is in the transfer case and is replaceable.
Old Feb 11, 2006 | 09:39 PM
stuart1's Avatar
stuart1
You can get a bit closer by installing a driven gear with more teeth on it.
btracy
Jan 8, 2013 05:46 PM
needhelp49
May 1, 2012 12:43 AM
Vin Man
Apr 24, 2012 05:29 PM
thunderb
17
Dec 10, 2007 11:36 AM
JUMBO_UTE
Oct 31, 2007 02:14 PM
