1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 F350 Lariat 7.3 Powerstroke
Old 10-29-2013, 07:04 PM
AlexIndy's Avatar
AlexIndy
AlexIndy is offline
I am interested in purchasing a 2004 F350 Lariat with the 6.0 Powerstroke engine. I would like to swap the engine with the 7.3 Powerstroke. What will this project require? Will engine mount location be the same? (easy bolt on?) How about transmission. I would like to use 2004 automatic transmission. Thank you!
Old 10-29-2013, 07:24 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
You will need a donor 7.3 truck so you can swap over the engine, transmission, wiring, computer modules, accessories etc. Almost nothing from the 6.0 can be re-used except for the coolers up front.
Good luck. Will be quite a project. Do you have emissions testing in your area?
Old 10-29-2013, 08:20 PM
AlexIndy's Avatar
AlexIndy
AlexIndy is offline
Thank you Shake-N-Bake for your reply.
Will I need to move engine and/or transmission mounts? I haven't welded for several years so I wondered if I'll have to change mount locations. I plan on manufacturing custom wiring harnesses for this project, maybe use little if any original 7.3 wiring.
Thank you.
Old 10-29-2013, 08:23 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
I have to ask what everybody else is wondering.
Why?
Old 10-29-2013, 08:29 PM
Krochus's Avatar
Krochus
Krochus is offline
Originally Posted by MisterCMK
I have to ask what everybody else is wondering. Why?
I'm not wondering.
I'm sure it involves something along the lines of a dirt cheap 04 with a deceased 6.0 and having a 7.3 or access to one
Old 10-29-2013, 08:38 PM
AlexIndy's Avatar
AlexIndy
AlexIndy is offline
I can get a good running 2001 stock 7.3 with 120,000 miles for $1200. I think will cost more to do a bullet proof mod with the 6.0.
Old 10-29-2013, 10:24 PM
Shake-N-Bake
You are going to need to use the entire under hood and engine harness from the donor truck including the battery cables and the fender mounted solenoid for the starting system. You need to use the PCM and IDM from the donor truck as well as the fuel pump and the instrument cluster.
If you are really going to try this swap, then you would be miles ahead to find a '02 or '03 donor 7.3 truck since there are some major differences with the under hood and cab wiring harnesses. Then your VSM and instrument cluster in your '04 may work (not sure about that last part but its worth a try...)
Old 10-29-2013, 11:33 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
If the 7.3 is running good but looks like crap then I would think it would be cheaper to replace all the skin and freshen up the interior then do the engine swap.
F350 SRW
01-06-2021 07:01 PM
Jesse Casey
06-22-2018 09:53 PM
Walleye Hunter
11-14-2015 11:34 PM
Yukon_IDI
02-22-2015 09:10 AM
meanjoelake
17
12-19-2011 02:09 PM
Quick Reply: 2004 F350 Lariat 7.3 Powerstroke
