i am getting icp error 2 on my banks six gun and it idles rough sometime and sometimes it don't idle down all the way any ideas what could be be the problem
- Turn off/Sell the Banks
- Get the engine code
- Repair/Replace parts as necessary with OEM parts
Unplug the ICP sensor, if there is oil on the connector it needs to be replaced. Unplug it with the engine on. If the idle changes, the sensor is good. If it doesn't change, the sensor is bad.
Get a good scanner, pull the engine code, check ICP values.
