Key warning switch
Key warning switch
I have a 1996 Ford F-150 and I just replaced the lock cylinder. Everything works fine, however, a alarm chimes when the key is out of the ignition, the headlights are off and the driver door is open, it stops when the driver door is shut. Is this normal? Or is the key warning switch faulty?
Received 3,186 Likes
on
no that is not normal. it is supposed to chime if the key is in the ignition when you open the door to let you know the key is still in the ignition so you do not lock it in the truck.
there is a little tab on top of the key cylinder that is not aligned properly. most people just disconnect it because it is a royal pain in the butt to get properly situated
There is a module that plugs in under the dash almost right above your right foot and transfer case if sitting in truck, you cant miss it. unplug that and no more chime and its the best for tailgaiting with stereo on and doors open.
just make it habbit not to leave lights on or keyes in. the chime wouldnt help most people with the issue of locking keyes in truck, that would take a whole lot more
nuts4hotwheels
06-20-2022 04:42 PM
ifyrlucky
08-07-2004 08:17 AM
