A little help?
Old Oct 20, 2013 | 02:08 AM
outrider79's Avatar
outrider79
A little help?
Hey all! New to the site, this is my first post...I'm Ron from Michigan, I have a '91 F150 with 160,000+ on a 5.0 that up until a few days ago ran like a dream. I pulled out of the driveway, got about a half mile down the road (never exceeding 25mph) and it suddenly just quit, no sputters or anything, simply stalled out. It turns over but won't catch. Got a half-tank of fuel in it.
I replaced the coil and the PCM module on the distributor, still no go. It used to have twin tanks, the switch is still in the proper position. Any thoughts?
Your input is greatly appreciated.
Old Oct 20, 2013 | 02:45 AM
Krisverde's Avatar
Krisverde
Does the fuel pump still prime?
Old Oct 20, 2013 | 07:37 AM
subford's Avatar
subford
^^^X2.
By the way that is a ICM on the distributor and not a PCM.
PCM: Powertrain Control Module, AKA the Computer.
ICM: Ignition Control Module and is of the circuit type TFI.
TFI: Thick Film Ignition or Integrated. An ignition module comprised of a custom integrated circuit, Darlington output device and associated thick film integrated components.
Old Oct 20, 2013 | 09:38 AM
EzPc's Avatar
EzPc
Sorry for the seemingly stupid suggestion but did you verify you have spark at the plugs? If so how?
Old Oct 20, 2013 | 10:17 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Verify that there is spark at the plugs. If you do not have spark, look for that problem. If you have good spark, check fuel pressure. If fuel pressure is steady and spark is good, Look into injectors not working. Sounds like electrical/electronic to me.
Old Oct 20, 2013 | 10:20 AM
bashby's Avatar
bashby
Not a stupid question at all. First thing to do is see why it cut off, did it lose spark or fuel?
karen palmer
Sep 19, 2014 08:13 AM
tundraathome
Nov 18, 2008 02:40 PM
76scout
Feb 24, 2008 06:23 AM
Ranger GT2
Electrical Systems/Wiring
Nov 20, 2007 11:54 AM
