Bad coil pack?
Bad coil pack?
I have a 97 F150 4.6. The truck has developed a slight stumble/missfire when under acceleration. Once at speed it runs fine. It has not given any codes. I've checked for them several times. The plugs and wires have been changed. Is it possable that a coil pack could be bad without throwing a code?
I would clean the mass air flow sensor and go from there
good luck and keep us posted
