bad coil
Old Dec 28, 2013 | 07:06 AM
edwardoh's Avatar
edwardoh
bad coil
03 150 4.6 I have a bad coil, question is, how to detect which one. The engine light is not on,thereby making the ob11 reader ineffective.Can someone please help?
Old Dec 28, 2013 | 07:39 AM
JWA's Avatar
JWA
Start engine, unplug each COP individually until this action yields no change.
Depending on which scanner you're using it should read a pending code for the misfire. Even though the CEL or MIL hasn't yet been triggered there shoujld be a readable code anyway.
Recently mine showed a misfire in the first 200 RPM's after ignition.
HTH
Old Dec 29, 2013 | 02:40 PM
edwardoh's Avatar
edwardoh
bad coil
Thank you JWA for your answer. Have tried ob11 and no codes, cant seem to find a consistant miss, it may be moisture from recent icestorm.
Old Dec 29, 2013 | 04:02 PM
Franklin2's Avatar
Franklin2
Why do you think it's a coil? Have you changed the sparkplugs recently?
Old Dec 29, 2013 | 05:22 PM
projectSHO89's Avatar
projectSHO89
That doesn't work for "mild" misfires. Likewise, there is no pending code in these circumstances unless and until the misfire counts have exceeded the failure threshold.
You will have to read the Mode 6 misfire count data.
royeco
Jan 25, 2017 01:26 PM
gunther32
1997 - 2003 F150
20
Jul 11, 2011 12:36 PM
Superdave
Jun 12, 2009 11:13 AM
dirt01
Modular V10 (6.8l)
Aug 31, 2007 02:37 PM
Soul-tez
3.8 & 4.2L V6
Mar 17, 2006 04:19 PM
