RUSTYQ
RUSTYQ
New user here. have a 97 F350 crew cab diesel 4x4. workn on front end and havind issues getting a replacement dust seal for the front end dana 60. The seal goes at end of dif tube on the inside boss of the inner drive axle. I keep getting the same part number for the outer seal on the outer drive axle on the hub side. 710413. Problem is the inside diameter is to big. I need one w 2 1/8 id. The outside one is 2 3/8. Same seal just different id. Anyone ever have this problem? Dealer cant even find the right part number.
on
Hi Rusty, welcome to FTE.
I see you are finding your way around FTE.
Stop by the VA chapter of FTE and give the locals a shout. You can find the chapter here,,,, Virginia Chapter - Ford Truck Enthusiasts Forums
Hi Rusty. I would look through the forums and find you model of truck and post a question in there and see if someone there can help you out.
There are lots of knowledgeable folks here who are more than happy to help in anwsering question and sharing some of their know how. Good luck, and have fun in the forums.
