need cold start help
I borrowed a friends mac tools scanner and here is what i found.
Cylinder contribution test-passed
buzz test-passed
injector control pressure is a bit low around 2200-2400psi wot
duty cycle was around 55 wot
I've replaced uvch and glowplugs on both banks
replaced relay
replaced ipc( had oil on it)
If its the least bit cold it cranks and wont start. If I cycle the glowplugs a few times it starts< sometimes rough and sometimes not. Either way it pukes white smoke and reeks of diesel fuel. It smells like its running rich even when its warmed up. i checked hpop res and oil level is fine. stripped allen bolt in the process.
I'll do whatever it takes to get er done. I like my truck and want to be able to go out in winter without having to plug it in.
by the way, when I plug it in it starts easy and purrs like a kitten.
the dash oil gauge jumps around like its havin a fit, if I take off the connecter on hpop and plug back in it seems to temp. solve that issue.
any help would be greatly appreciated.
buzz test-passed
replaced relay
This is the key. More important than whether there's voltage at all on the second terminal, or whether you hear it click. It'll even show up as lower voltage on the meter on the dash, and it will energize the glow plugs, just insufficiently. So if the _difference_ between the two terminals _while_ the GPs are running is more than 0.3V, the relay is bad, even though it's closing.
BTW, to the OP, if by "cycling the key", you mean you're turning it off when the WTS light goes off and turning it back on, you're wasting your time and prematurely aging the GP relay. The glow plugs stay on long after the WTS light goes off. About one to two minutes, depending on oil temperature. So just leave the key in RUN for an extra 10-20 seconds. And make sure that the dash voltmeter indeed stays low for that period. That still indicates a possible glow plug issue, however.
Have you inspected the UVCH connectors? Can you get your hands on your friend's scanner again, and monitor EOT (oil temp) when you first start it and as it warms up?
Intense_Spence
11-23-2008 11:25 AM
