Pats Has My Excursion Down Need Help!
Hello All and thanx in advance for any help you can give. Here's my issue:
A week ago my ex just died while driving. Theft light flashes rapidly then gives the code 1.6. So, I think Pats has problem, key, communicator, whatever. Then I think, I don't want pats anyway and I've wanted a tuner for a while now. So I get a custom Tuner that will tune the vehicle and disable pats. Great right! Wrong! I finally got 1 tune to load, the ex still will not start. And now the tuner cannot take the vehicle back to stock and I'm staring up the short end of a tow to the dealer. Not cool. So here's my newest thought and looking for advice on this one before I go ahead. Maybe my ecu is just shot. Oh, by the way my tuner will not read any dtc either. Here are my questions.
1. So if the ecu is shot I replace it right?
2. If I do can I use a v-10 sd ecu that wouldn't have pats?
3. If I do that can I re-flash that to run my ex?
4. If the sd ecu is not an option can I swap to an ex ecu?
5. If I go with the ex ecu do I need to flash it to work in my ex?
Any, other tips and advice would be most helpful. I need my ex back badly!
Thanx again.
TK71
Thanx again.
TK71
Stiil no luck with ex.
No, still don't have the excursion up and running. Checked the fuses and for loose wires and still can't find anything.
Anyone, know a definite way to check if the pcm/ecu is bad?
I tried the scrap yard figuring for $25 bucks I could test out my theory of reprogramming a different computer. No, luck. The yard man looked at me cross eyed when I said I was looking for a v-10.
So, yeah probably looking for a new pcm/ecu.
Any other suggestion on testing the computer I would love to hear.
on
Call Mike at Mike's 5 Star and discuss with him. He also sells fully operational pcm's along with the best programmer for V-10's.
5 Star Tuning | Custom Dynomemeter Chassis Tuning Products and Services
jdadamsjr
05-29-2003 07:23 AM
