windage tray 351w engine
looking for a windage tray for my 89 f250 351w truck.
NPD is out of stock
found some on ebay and other places
what do you guys suggest? do i want a stud girdle as well? its just a work truck but thought i would do some extra upgrades whiles its out and apart.
the engine has less then 10,000 miles on the rebuild. has shorty headers and a ford towing cam installed. thats what the previous owner told me about the engine.
what are your suggestions.
oh here is another thread i put up on another forum with links to ones ive found
my 351w ford parts search - The Garage Journal Board
NPD is out of stock
as far as the headers, i agree with you there. these are the headers that are on there from the previous owner. i havn't been able to find actual long tubes but mid length. might switch them as of yet just havn't ordered those.
as far as the windage tray, its more of a just because i can rather than a really needed thing. it might be of some help going down the highway but likely not much.
also just because i can.
Only time I used a windage tray was in a 7000+rpm drag engine. As far as roller rockers, they're nice but not essential for long life. Many folks buy all kinds of high dollar parts and then use a second rate machine shop. If you want it to last use the best machine shop you can find in your area and be as meticulous as you can when reassembling everything. Balancing the reciprocating assembly will get you a long way down the road. The whole roller rocker thing is nice but unless you're building an engine that can benefit from the expense, dropping $500-1000 for roller rocker setup is just not worth it. I'm in the process of rebuilding my 94 300 and when I pulled it apart everything was in pretty good shape. The bearings were just worn out. The valve train was in great shape. a set of bronze wall guides a three angle job, new exhaust seats, and a clean up cut was all it needed. These truck engines are pretty darn tough.
I agree money could be spent in a much better way IMHO. Heads, different header, a programmer, gears (depending on usage) A different stall converter. the list goes on, but first you have to decide what you want to accomplish in the end.
Craig
BossFan
17
03-06-2019 08:04 PM
Gigemags05
32
01-11-2015 08:21 PM
AstroFab
11-16-2011 07:13 PM
mrsuperman15
01-24-2005 11:54 AM
