C-bushing replacement
Old 08-08-2013, 11:30 PM
Oldbone's Avatar
Oldbone
Oldbone is offline
I have a 76 F150 4x4. It has what appears to be a factory lift kit. The blocks on the rear springs are anvil shaped and 3 1/2" tall. I am guessing I will need the 4 degree replacement c-bushings? Any confirmation would be greatly appreciated.
Old 08-08-2013, 11:51 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Stop.
The rear blocks are OEM and at OEM height if there are no other blocks and OEM leaf packs.
The degreed C-bushings are for the front when there is a lift installed over and above the OEM height.
Do you know if you have more lift than OEM??? A 4-degree C-bushing is for a 2- to 4-inch lift. From your description of the OEM rear blocks, I assume that the front is not lifted at all and thus does not require any corrected C-bushings to restore lost caster when it is lifted.
Old 08-09-2013, 12:15 AM
Oldbone's Avatar
Oldbone
Oldbone is offline
Correct nothing but the rear blocks. Looks like that would be the 2 degree then. Much thanks
Old 08-09-2013, 12:26 AM
460 FORD MAN's Avatar
460 FORD MAN
460 FORD MAN is offline
Like HIO said,
"The degreed C-bushings are for the front when there is a lift installed over and above the OEM height."
If the blocks in the rear are stock you do not need degree c-bushings
Old 08-09-2013, 12:28 AM
Oldbone's Avatar
Oldbone
Oldbone is offline
Thanks again Guys. That's why I asked first. I really appreciate the help.
Old 08-09-2013, 01:08 AM
keiths78f150's Avatar
keiths78f150
keiths78f150 is offline
Are you positive there is a rear lift?
Old 08-09-2013, 09:44 PM
Oldbone's Avatar
Oldbone
Oldbone is offline
I'm not positive. Only thing it has is the 3 1/2" anvil blocks in the rear. No other blocks front or back and no added leaves. I assumed the blocks in back meant it had a lift. Maybe that is stock as in no lift for these trucks. Looks like HIO is saying that is considered no lift for these trucks. The 2 degree bushings state for no lift up to 2" inch lift so looks like those will be the ones I am getting.
Old 08-09-2013, 09:57 PM
HIO Silver's Avatar
HIO Silver
That is correct. Just the anvil blocks means there is no lift.
Yep. I recall someone out there lists a 0-2"-lift C-bushings.
Old 08-09-2013, 10:53 PM
keiths78f150
HIO said it all.
swampsuperduty
Offroad & 4x4
18
04-18-2012 08:59 PM
john8403
02-03-2012 09:17 PM
1bad67sbf
2004 - 2008 F150
03-24-2010 11:44 AM
jdhudall
1997 - 2003 F150
12-06-2007 05:27 PM
esco24
1999 to 2016 Super Duty
11-09-2007 12:03 AM
Quick Reply: C-bushing replacement
