i put a level kit on and want the rear higher, what is better lift blocks or add a leaf? i dont haul much but sometimes have a trailer with misc stuff. also how long are the u-bolts for a 1in lift
this is why i want to raise the rear, the front is almost higher than the rear
i take it you removed the factory lift block and installed the 3in. how much lift did you end up with above stock in the rear and do you have a pick of the truck w/ 2.5 front and 3 rear
