C-bushing replacement
Old Aug 8, 2013 | 11:30 PM
Oldbone's Avatar
Oldbone
I have a 76 F150 4x4. It has what appears to be a factory lift kit. The blocks on the rear springs are anvil shaped and 3 1/2" tall. I am guessing I will need the 4 degree replacement c-bushings? Any confirmation would be greatly appreciated.
Old Aug 8, 2013 | 11:51 PM
HIO Silver's Avatar
HIO Silver
Stop.
The rear blocks are OEM and at OEM height if there are no other blocks and OEM leaf packs.
The degreed C-bushings are for the front when there is a lift installed over and above the OEM height.
Do you know if you have more lift than OEM??? A 4-degree C-bushing is for a 2- to 4-inch lift. From your description of the OEM rear blocks, I assume that the front is not lifted at all and thus does not require any corrected C-bushings to restore lost caster when it is lifted.
Old Aug 9, 2013 | 12:15 AM
Oldbone's Avatar
Oldbone
Correct nothing but the rear blocks. Looks like that would be the 2 degree then. Much thanks
Old Aug 9, 2013 | 12:26 AM
460 FORD MAN's Avatar
460 FORD MAN
Like HIO said,
"The degreed C-bushings are for the front when there is a lift installed over and above the OEM height."
If the blocks in the rear are stock you do not need degree c-bushings
Old Aug 9, 2013 | 12:28 AM
Oldbone's Avatar
Oldbone
Thanks again Guys. That's why I asked first. I really appreciate the help.
Old Aug 9, 2013 | 01:08 AM
keiths78f150's Avatar
keiths78f150
Are you positive there is a rear lift?
Old Aug 9, 2013 | 09:44 PM
Oldbone's Avatar
Oldbone
I'm not positive. Only thing it has is the 3 1/2" anvil blocks in the rear. No other blocks front or back and no added leaves. I assumed the blocks in back meant it had a lift. Maybe that is stock as in no lift for these trucks. Looks like HIO is saying that is considered no lift for these trucks. The 2 degree bushings state for no lift up to 2" inch lift so looks like those will be the ones I am getting.
Old Aug 9, 2013 | 09:57 PM
HIO Silver's Avatar
HIO Silver
That is correct. Just the anvil blocks means there is no lift.
Yep. I recall someone out there lists a 0-2"-lift C-bushings.
Old Aug 9, 2013 | 10:53 PM
keiths78f150
HIO said it all.
swampsuperduty
Offroad & 4x4
18
Apr 18, 2012 08:59 PM
john8403
Feb 3, 2012 09:17 PM
1bad67sbf
2004 - 2008 F150
Mar 24, 2010 11:44 AM
jdhudall
1997 - 2003 F150
Dec 6, 2007 05:27 PM
esco24
Nov 9, 2007 12:03 AM
