Misfire at idle
Old 07-28-2013, 07:20 PM
Tom's Avatar
Tom
Tom is offline
Misfire at idle
Hi everyone,
I've mentioned this a couple of times before but finally got around to taking a video. Has anyone had this happen to them, and if so what was the fix? I want to take it in at some point but can't afford to be without a truck at the moment.
It does this without fail on every cold startup. After a few seconds it smooths out. I see the white smoke most of the time as well, no clue what's causing it.
ON edit: WOW the audio quality is awful. I'll try to shoot another one either tonight or tomorrow.
Old 07-28-2013, 07:30 PM
Tom's Avatar
Tom
Tom is offline
Crap...it hasn't sat long enough to really misfire this time.
Old 07-28-2013, 08:07 PM
PrinceValium's Avatar
PrinceValium
PrinceValium is offline
I don't know about a misfire..a lot of times I will use the reemote start to get the oil circulated before I drive away. What I DO hear is something like w howl from the turbo. The last OP that had that had his turbos replaced. Do you remember seeing that thread?
Old 07-28-2013, 09:21 PM
Charlie Bravo's Avatar
Charlie Bravo
Charlie Bravo is offline
Crazy, mine does the same. I ain't gonna worry about it, it runs good. Best, CB
Old 07-28-2013, 09:47 PM
doocrue's Avatar
doocrue
doocrue is offline
I have had same issue for quite sometime. The diagnosis on mine was a misfire on cylinder #3. I have't had time to take mine in since I need it every day. It runs fine when warm and pulls good. Just cold starts.
Old 07-28-2013, 09:52 PM
vloney's Avatar
vloney
vloney is offline
PCED directs you to start at the injectors for a misfire at idle. PPT DI
Old 07-29-2013, 07:27 AM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
Originally Posted by Crazy001
Hi everyone,
I've mentioned this a couple of times before but finally got around to taking a video. Has anyone had this happen to them, and if so what was the fix? I want to take it in at some point but can't afford to be without a truck at the moment...
Hi Crazy001,
Send me your information so I can see how to best help. I'll need a PM from you with your VIN, dealer, mileage, daytime phone number, and full name; I'll start researching some options.
Crystal
Old 07-29-2013, 04:59 PM
Charlie Bravo
Since mine is doing the same I'll be watching this. Best, CB
Old 07-29-2013, 06:48 PM
Tom's Avatar
Tom
Tom is offline
I replied to Crystal via PM as requested, and she's notifying the regional customer service rep.
My concern is mainly long-term. Catalytic converter damage can occur with a misfire, so what's going to happen to them over the long run?
Old 07-29-2013, 08:08 PM
Eco12's Avatar
Eco12
Eco12 is offline
Will also be following. My '12 exhibits the same issue. Keep us posted.
Old 07-29-2013, 08:36 PM
meborder's Avatar
meborder
meborder is offline
this may be part of ford's warm-up strategy in order to reduce emissions on a cold engine. retard the ignition and exhaust camshaft timing to get the cats online very soon after start up.
http://media.ford.com/images/10031/TiVCT.pdf
will be following as well
Old 07-29-2013, 08:39 PM
doocrue's Avatar
doocrue
doocrue is offline
Count me in on following this too.
Old 07-30-2013, 01:16 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
could this be a oil blow-by issue from the pcv
I know the 4.6 and 5.4 are notorious for oil getting sucked back into the intake. My 2009 Bullet had an oil soaked intake with <6,000 miles...and my 2006 F-150 had the intake oil soaked at 22,000 miles.
alot of guys install catch cans and will collect several ounces of oil over the course of 3-5,000 miles.
seeing that white smoke on start-up makes me think of oil. you guys could have oil collecting in the intake and at idle when the motor is cold, that little bit of oil is getting sucked in.
I'd be curious to see what your looks like where the air feed is bolted to the intake. run an inspection mirror down in there and see how clean/dirty it looks
Old 07-30-2013, 08:38 AM
Christin's Avatar
Christin
Christin is offline
Hi everyone,
That is not a misfire. That is normal startup for a direct injection turbocharged gasser. My ecoboost and my Mazda 2.3l Disi turbo both do the same. No worries totally normal
Old 07-30-2013, 09:20 AM
Tom's Avatar
Tom
Tom is offline
I know what you're talking about, but unfortunately the audio is lousy on that video and you can't hear it. Not sure what happened with the audio on that one, but I will try and get a better one tomorrow morning.
It is definitely misfiring; my wife started the truck on that first clip and commented on how much the truck shook.
Quick Reply: Misfire at idle
