4X2 midship fuel tank sender avaliablity - ?
Has anyone ever come across a company that sells this? I was about to order from LMC but there's is for a 4X4. Seems like it's a little harder to find than I was hoping. 1976 F250 Supercab camper - if anyone has a clue to where to look I would greatly appreciate it!
Gauge, fuel level sending unit
74-76 F100-350 2WD Supercab
before s/n C00,000
D4TZ-9275-A replaced by D7TZ-9275-C
after s/n C00,000
D7TZ-9275-C
I located 1 NOS unit but they want $175.00 (!!) for it.
NOS Parts Ltd.
Waxahatchie, TX has 1 (972) 937-2201
Personally, I'd go with the one from JBG.
before s/n C00,000
after s/n C00,000
D7TZ-9275-C
NOS Parts Ltd.
Thanks all. I was about to order that one from The Bronco website...but it is different than the one I pulled out! Unless mine was not correct; that one looks totally different. Can anyone verify that the one on V10mamns link above is correct?
** And I have the Supercab if that makes any difference!
Yeah, I had better pass on the $175.00 cost!!
Appreciate it.
Appreciate it.
1974/79 Super Cab 2WD mid-ship fuel tank sending unit availability
It's made from two pieces of copper soldered together, solder breaks down, gas seeps in, float settles to the bottom of the tank.
Remove the float, shake it to hear if gas is sloshing around inside.
COAZ-9202-B .. Fuel Sending Unit Float / Available from Ford / ALL 1957/79 Passenger Cars/Trucks, 1961/79 Econolines & 1966/79 Bronco's.
Carpenter sells a one piece 'replacement' brass float for around 5 bucks that'll never leak.
Note: NOS PARTS LTD in Waxahachie TX has the original D4TZ-9275-A sender .. not the D7TZ-9275-C replacement.
The issue with the sending unit is electrical...the side tank was unused for who knows how many years and things are all gummed up. I tried to cleanup the resistance wire and attached the green wire to the stud but it is in sad shape.
I found a place in Hemmings to rebuild it for $135.00 - may be my option unless I can make something else work...?
I will get a picture up here later Friday...its is clearly different than the regular and maybe even crew cabs.
old28
16
04-22-2019 10:03 PM
eriklane
11-09-2012 08:36 PM
jrr31977
03-18-2009 06:34 PM
Justntimeracing
15
10-05-2004 06:06 PM
