Fuel Tank Sending Unit...
Old Oct 3, 2004 | 03:46 PM
Justntimeracing's Avatar
Justntimeracing
Cool Fuel Tank Sending Unit...
anyone have a fuel tank sending unit for my 1971 Ford F-250 Camper Special. I need one for the main in cab tank. I found some new ones for sale but, can't afford what they are asking. Any one got a new or good used one they would sell me? Or does anyone know of there are rebuilt kits or of someone that rebuilds them. Would appreciate any help.
Phil
Old Oct 3, 2004 | 05:23 PM
Mil1ion's Avatar
Mil1ion
Why not try taking it out an cleaning it up first ?
Most times it's the lack of ground that causes the problem.
New ? Motorhaven should have a couple left
Old Oct 3, 2004 | 05:52 PM
towrig302's Avatar
towrig302
And if it's the float that's bad, they're about $5.00.
Old Oct 3, 2004 | 06:44 PM
elemint's Avatar
elemint
How do you replace a float? My fuel gauge only goes to 3/4 and is empty at 1/4. I also hear a lot of ticking in the tank when i am going slow and hitting bumps. Count that be a bad float?
Old Oct 3, 2004 | 08:12 PM
GolferSA's Avatar
GolferSA
Dennis, I'm not finding them in a search on MotorHaven.
Phil, is this what you're after?
http://www.parts123.com/parts123/yb....0000021f~FCAPA
C1TZ-9275-KR Each 59.95 Gas Tank Sending Unit 18 Gallon In Cab Tank Only F100-f350 1 1961-1977
Mac's Antique Auto Parts
http://www.parts123.com/PartFrame.as...que_Auto_Parts
Old Oct 5, 2004 | 08:01 AM
nnickty's Avatar
nnickty
Dennis Carpenter has 428 of what I'm sure are reproductions. I found a couple more places that "MIGHT" have NOS. Some of the NOS guys also sell repo's, but it's too early to call!!!
Old Oct 5, 2004 | 08:18 AM
nnickty's Avatar
nnickty
WOW! That's a great price from Mac's! I'm sure they get them from Dennis Carpenter and Dennis retails them at $65.00! Reproductions usually, but not always, work just fine. It generally comes down to how long they'll work rather than how well. But then again I've put NOS items on cars, such as fuel senders and turn signal switches, that didn't make it a year. If you are interested in an NOS sender post here and I'll check on price and availibility.
Old Oct 5, 2004 | 12:53 PM
Justntimeracing
thanks guys, but, i am looking for a good used or rebuilt one. i just can't afford a new one at this time i leave on a cross country trip in less than 2 weeks, and it's taking everything i have. Anyone, have a good used, rebuilt, fuel tank sending unit for the in-cab main tank for my 1971 Ford F-250 Camper Special? I need your help.
Old Oct 5, 2004 | 02:09 PM
WillyB's Avatar
WillyB
If it is working between 3/4 and 1/4 tank, why not try to bend the arms to get full scale deflection? Just remove the sender from the tank and run it by hand to see if it can indicate full and empty - if it does all you need to do is adjust the arm that holds the float untill it moves the same amount in the tank.
Old Oct 5, 2004 | 03:17 PM
elemint's Avatar
elemint
Sounds like a good plan... But now why is a 18 or 20 gallon tank only holding 10 gallons?
Old Oct 5, 2004 | 05:03 PM
WillyB's Avatar
WillyB
One of my long deceased relatives used to drop any change he got when filling his tank into the tank of his Model A - When he was ready for a new car, he removed the tank and emptied his piggy bank.
At least that is how he explained how he got money enough for a new car during the Depression - my grandfather always called him a boot-legger.
Anyway, maybe your tank is full of treasure!!!!
Old Oct 5, 2004 | 05:36 PM
71 Muddbugg's Avatar
71 Muddbugg
I went on ebay and got one for $10. The guy gauranteed it worked so I bought it. I changed it out but nothing worked. I got a hold of the guy I bought it from and he said he tested it and it did worked. I wonder, does both the positive and negative wires go to the dash guage or does the negative ground on the body? Maybe one or both of the wires are toast because my gas guage never worked from the time I bought it.
Old Oct 5, 2004 | 05:55 PM
Justntimeracing
muddbugg, wish i could find one for 10.00. to answer your questions... does your truck have dual tanks with a main, and aux switch on the dash? if so, what you need to do is remove the orange wire from the top of the in-cab main tank sending unit, and with the switch on the dash set on the main tank, take a jumper wire, and connect one end to the orange wire, and the other end to a good ground the fuel gauge needle should go to full. if it does not the gauge, wiring or the switch on the dash is bad try this, and get back to me. Phil
Old Oct 5, 2004 | 06:02 PM
Justntimeracing
anyone got a good used, rebuilt, new fuel tank sending unit for the in-cab main tank that they would sell me cheap for my 71 ford f-250 camper special. i have a extra dash instrument cluster complete with all the gauges less the bezel i would sell or trade....
71 Muddbugg
I only have an in cab tank
