Banks speedbrake
Banks speedbrake
Well been meaning too for awhile so I ordered the speedbrake to go along with my 6-gun and of course the IQ (gauges).
Banks Power | 08-10 Ford - 6.4L Power Stroke>>Banks SpeedBrake
It has three different settings. Off, manual and auto.
In the off then it will not be applied.
In the manual mode you can engage it in low, med or high settings with high being the most aggressive. Might want med or high only when towing.
You can also have it only come on when you apply the brakes or when you let off the skinny pedal.
In the auto mode it will come on automatically when you let off the fuel. This also requires that you specify a speed to low down to. (40, 50, 55 or whatever speed you wish to maintain).
So far very pleased with it. Easy to connect. Cruise/tow haul all functions still work.
I am not so good at pics but I snapped a few.
It hooks to your brake pressure switch on the master cylinder and the brake pedal switch under the dash and finally the tow haul connection on the steering column.
I took the back off the suction cup and then I went to a radio shop and got a mount that they use for radios and screwed it in the spot where the 4x4 switches are. So it is no mounted to the vent. It is mounted on the switch area as I don't have anything there.
Wire is of course run under the dash up to it.
I am just going to have to screw it to fold down cup holder, your first location for now am thinking about air bags too. Thanks for the pics i have 4x4 switchs on the dash
