Sponsored by: Real Truck
Tow/haul question
Old Jun 24, 2007 | 08:40 PM
brunob's Avatar
brunob
Tow/haul question
I have a 2003 F350 6.0l dually and towing a fith wheel(10 000pounds). I was wondering when towing and the tow/haul is ON, at what speed it should kick in and slow down on it's own? It's seem that I have the slow down by applying the brake and them it kicks in. Is this normal?
Old Jun 24, 2007 | 10:33 PM
heavyiron's Avatar
heavyiron
Yes, thats normal. You wouldn't want it to come on all the time you had your foot off the go pedal !!
Old Jun 24, 2007 | 11:08 PM
conger's Avatar
conger
Mine kicks down at 80kph/50mph and then again at 60kph/40mph. I usually leave it on on the highway when I'm towing, but I usually leave it off at very low speeds, like when I'm looking for a spot in a campground. Towing a heavy load in the city, I just leave it on. Saves the brakes. Also I won't turn it on if I'm coasting in gear at 30mph or less, since sometimes it will make a hard bang when the solenoid engages. May or may not be normal, but it's not a problem for me.
Old Jun 24, 2007 | 11:12 PM
DonJames's Avatar
DonJames
I was told by the dealer salesman that the Tow/Haul kick-down reaction depended on the amount of brake pedal pressure. It might say in the owner's manual:
https://www.fleet.ford.com/maintenan...ls/default.asp
