Aerostar Ford Aerostar
93 Aerostar can clockspring be repaired
Old 06-11-2003, 02:03 PM
Hosea2003's Avatar
Hosea2003
Hosea2003 is offline
Question 93 Aerostar can clockspring be repaired
Hi. I have a 93 Aerostar 4.0 and it is displaying the blinking airbag light (3-2) and the horn doesn't work and the cruise control failed. I believe it is the clockspring. QUESTION:
Can the clockspring be repaired or must it be replaced. I do not have a schematic of the electrical components of the clockspring so I really need help on this. Trying to avoid the $132.00 price of a new clockspring. Thanks
Old 06-11-2003, 02:34 PM
aerocolorado's Avatar
aerocolorado
aerocolorado is offline
There was a problem with some of the early airbag equipped models with the electrical leads being too short and stress failures. With all your components out, I would bet you have just broken the leads. Whether or not you can just repair them with jumpers, I don't know, mine is not similarly equipped. No harm in opening it up and checking for broken leads.
Old 06-11-2003, 03:26 PM
Hosea2003's Avatar
Hosea2003
Thanks for your reply. I will take out the airbag this evening and see what it takes to get to the clockspring. I think I have to pull the steering wheel completely off to get to it.
Hosea2003
Old 06-12-2003, 08:29 PM
01RangerSC's Avatar
01RangerSC
01RangerSC is offline
There is no way to repair a clockspring. It will have to be replaced. To access it, remove the steering wheel and the plastis steering column trim. It will also have a couple or wiring connectors that extend down about 8-10 inches. BEFORE REMOVING OR RE-INSTALLING THE AIRBAG, MAKE SURE YOU DISCONNECT THE BATTERY AND WAIT ABOUT 10 MINUTES FOR THE BACKUP BATTERY TO DEPLETE!!!!!!!!!!!!!
Old 06-13-2003, 01:05 AM
Hosea2003's Avatar
Hosea2003
Thanks alot for the advice. I bought a new clock spring at the dealer. It took me about an hour or so to replace it. Everything works like a charm again! The airbag light quit blinking 3-2; the horn honks and the cruise control works. Driving from Las Vegas to San Antonio this coming weekend; and yes, I did remember to disconnect the battery for 20 minutes before I took the airbag off and before I put the airbag back on.
Thanks to all of you for your help. Love this forum
Old 07-03-2003, 07:14 PM
scottu's Avatar
scottu
scottu is offline
hay i have the same problem could you tell me how to do this??
scott
Old 07-04-2003, 04:21 AM
Hosea2003's Avatar
Hosea2003
I disconnected the ground to the battery and left it alone for 20 minutes. Then unscrewed the four screws behind the steering wheel that hold the airbag in place. LIfted out the airbag very carefully pointing it away from me and disconnected the wires from it then put it in safe place away from kids. Disconnected the rest of the leads to the cruise control and horn. Used a puller to pull the steering wheel off. Pulled the panel off under the steering wheel and the pulled the panel off that covers the steering column. Followed the wires from the clockspring to under the dash and disconnected them. Removed the old clockspring; installed the new clockspring connecting the wires to the same connections under the dash. It comes with a few extra connections, but they are already taped off. Just use the ones that match your old clockspring. Remember to keep the negative ground from the battery disconnected until after you have reassembled everything so the capacitor for the airbag doesn't charge up and accidently activate the bag. Anyway, this is a synopsis of what to do. Hope it helped you.
Archie
Old 10-10-2003, 06:09 PM
dem_dingbat's Avatar
dem_dingbat
dem_dingbat is offline
Other than being annoying, what problem might occur? Will the airbag not function?
Old 01-05-2011, 02:53 PM
dogussagir's Avatar
dogussagir
dogussagir is offline
There won't be any problems other than the airbag, horn and cruise buttons will not function.
Old 08-26-2012, 09:17 PM
Muffinman's Avatar
Muffinman
Muffinman is offline
That is not true, most clock springs fail from broken ribbon cable inside. You can repair this easy with a sodering iron and silver solder.
MCR500
1997 - 2003 F150
05-26-2014 11:55 PM
Lx460
1999 to 2016 Super Duty
08-06-2013 07:23 PM
natew
03-29-2013 03:27 PM
CdnSoldier
Aerostar
21
05-22-2011 07:01 PM
yourmineby9
06-08-2006 07:21 AM
Quick Reply: 93 Aerostar can clockspring be repaired
