93 Aerostar can clockspring be repaired
Hi. I have a 93 Aerostar 4.0 and it is displaying the blinking airbag light (3-2) and the horn doesn't work and the cruise control failed. I believe it is the clockspring. QUESTION:
Can the clockspring be repaired or must it be replaced. I do not have a schematic of the electrical components of the clockspring so I really need help on this. Trying to avoid the $132.00 price of a new clockspring. Thanks
There was a problem with some of the early airbag equipped models with the electrical leads being too short and stress failures. With all your components out, I would bet you have just broken the leads. Whether or not you can just repair them with jumpers, I don't know, mine is not similarly equipped. No harm in opening it up and checking for broken leads.
There is no way to repair a clockspring. It will have to be replaced. To access it, remove the steering wheel and the plastis steering column trim. It will also have a couple or wiring connectors that extend down about 8-10 inches. BEFORE REMOVING OR RE-INSTALLING THE AIRBAG, MAKE SURE YOU DISCONNECT THE BATTERY AND WAIT ABOUT 10 MINUTES FOR THE BACKUP BATTERY TO DEPLETE!!!!!!!!!!!!!
Thanks alot for the advice. I bought a new clock spring at the dealer. It took me about an hour or so to replace it. Everything works like a charm again! The airbag light quit blinking 3-2; the horn honks and the cruise control works. Driving from Las Vegas to San Antonio this coming weekend; and yes, I did remember to disconnect the battery for 20 minutes before I took the airbag off and before I put the airbag back on.
Thanks to all of you for your help. Love this forum
I disconnected the ground to the battery and left it alone for 20 minutes. Then unscrewed the four screws behind the steering wheel that hold the airbag in place. LIfted out the airbag very carefully pointing it away from me and disconnected the wires from it then put it in safe place away from kids. Disconnected the rest of the leads to the cruise control and horn. Used a puller to pull the steering wheel off. Pulled the panel off under the steering wheel and the pulled the panel off that covers the steering column. Followed the wires from the clockspring to under the dash and disconnected them. Removed the old clockspring; installed the new clockspring connecting the wires to the same connections under the dash. It comes with a few extra connections, but they are already taped off. Just use the ones that match your old clockspring. Remember to keep the negative ground from the battery disconnected until after you have reassembled everything so the capacitor for the airbag doesn't charge up and accidently activate the bag. Anyway, this is a synopsis of what to do. Hope it helped you.
Archie
Archie
That is not true, most clock springs fail from broken ribbon cable inside. You can repair this easy with a sodering iron and silver solder.
Lx460
1999 to 2016 Super Duty
08-06-2013 07:23 PM
