94 F150 clockspring
Old Jun 7, 2006 | 05:42 PM
yourmineby9's Avatar
yourmineby9
94 F150 clockspring
I am hoping someone out there can steer me with some info on changing out my clockspring in my truck. I have the blinking air bag, no cruise, no horn thing going on and am hoping It is not to complicated to change. Thanks
Old Jun 7, 2006 | 05:57 PM
wildcard30's Avatar
wildcard30
Have you tried doing a search on this subject?
I think I posted the info on this a couple months ago.
If you can't find it I post the info again.
Old Jun 7, 2006 | 06:05 PM
wildcard30's Avatar
wildcard30
Here you go....
I found my original post. Hope this helps.....
I also put the Air Bag light codes at the bottom of the post.
If it's the clock spring, here's the general procedure to remove and replace it..
Air Bag Sliding Contact
1. WARNING: THE BACKUP POWER SUPPLY ENERGY MUST BE DEPLETED BEFORE ANY AIR BAG COMPONENT SERVICE IS PERFORMED. TO DEPLETE THE BACKUP POWER SUPPLY ENERGY, DISCONNECT THE BATTERY POSITIVE CABLE AND WAIT ONE MINUTE.
Disconnect the battery positive cable and wait one minute for the backup power supply energy to be depleted.
2. Make sure the vehicle's front wheels are in the straight-ahead position.
3. Remove the driver side air bag module (043B13)
4. Remove the steering wheel (3600).
5. CAUTION: Do not apply excessive force to the air bag sliding contact (14A664).
Turn the air bag sliding contact clockwise until it stops.
6. Rotate the air bag sliding contact counterclockwise 2.75 turns.
7. Align the marks on the air bag sliding contact with the marks on the outer housing.
8. Install the steering wheel.
9. Install the air bag module
as described in Module, Driver Side Air Bag, Removal and Installation in this section.
10. NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
Connect the battery positive cable.
11. Verify that the air bag indicator is operative.
Here's the trouble code chart
CODE COMPONENT/FAULT
12 Low Battery voltage
13 Air Bag Circuit Shorted to Ground
14 Front Air Bag Sensor and Bracket Circuit Shorted to Ground
21 Rear Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
22 Rear Air Bag Sensor and Bracket Output Circuit Shorted to Battery Voltage
23 Rear Air Bag Sensor and Bracket Circuit Input Feed/Return Circuit Open
24 Rear Air Bag Sensor and Bracket Output Feed/Return Circuit Open
32 Driver Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
41 RH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
42 LH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
44 RH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
45 LH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
51 Air Bag Diagnostic Monitor Internal Thermal Fuse - Fuse Blown Due to Intermittent Short to Ground
52 Backup Power Supply - Voltage Boost Fault
53 Front Air Bag Sensor and Bracket Circuits Resistance to Ground or Air Bag Diagnostic Monitor Fault
- Rapid Continuous Flashing of Air Bag Indicator (No Fault Code) All Primary Air Bag Sensors Disconnected
- No Air Bag Indicator - Inoperative Indicator Circuit or No Battery Positive Voltage to Air Bag Diagnostic Monitor
- Continuous Air Bag Indicator - Air Bag Diagnostic Monitor Disconnected or Inoperative
Old Jun 7, 2006 | 06:20 PM
quicklook2's Avatar
quicklook2
i will add ALWAYS think that the bag can go off at any time and always hold it away from the body.
Old Jun 8, 2006 | 07:21 AM
Scndsin's Avatar
Scndsin
Recently did the same repair for the same problem. The replacement clock spring should come packaged with a plastic spider that holds the spring assy & keeps it "clocked" & from moving during shipping. Also be very careful of the bolt holes on the steering wheel where your wheel-puller attaches. The threads are shallow, the material aluminium & strips quite easy.
Ajk Tek
May 28, 2017 09:17 AM
HStrip
Apr 27, 2017 04:16 PM
Metalhead47
Mar 29, 2016 07:04 PM
JRS2
21
Oct 31, 2015 10:04 AM
Lx460
Aug 6, 2013 07:23 PM
