How do I remove interior door panel to get regulator out?
Driver side window regulator slowly getting worse window feels out of track and doesnot operate smoothly. I've never taken off the door panel to get in to checkit out and see what needs to be done to fix. Can some post here or share a link with pics on door panel removal and window regulator replacement for 68 or similar? Thank you
Ah... you have them fancy panels.
Unscrew the window crank... center of the shaft and there will be an escutcheon behind to prevent the crank from scraping. Bag and tag!!!
Unscrew the door latch... I recall there are two screws.
For the door panel, the screws are under the perimeter trim. I'm not sure how to remove the trim cuz I got a plain ol' Custom model. .... a fellow FTE'er will come along shortly with experience on them panels. Patience.
Driver side window regulator slowly getting worse window feels out of track and does not operate smoothly. I've never taken off the door panel to get in to check it out and see what needs to be done to fix.
Parts catalog captions are in error inre to window parts/handle and latch parts. 1968/72 same, 1967 is ONE YEAR ONLY!
DPDISXR4Ti
02-15-2013 07:58 AM
alpine
03-24-2003 05:34 PM
