Removeing door panel?
Old Mar 21, 2009 | 08:49 PM
rjkempf91's Avatar
rjkempf91
I trying to remove the door panel, how do you remove the manule door crank? is there a (c) ring that i need to remove?
Old Mar 22, 2009 | 08:57 PM
michigan66's Avatar
michigan66
Pull the plastic cover on the window crank. There is a Phillips headed screw that needs to be removed in order to pull the window crank off.
