Drivers Door Panel
Old Dec 2, 2005 | 07:30 AM
RTEGEL's Avatar
RTEGEL
Drivers Door Panel
I was rolling down my drivers window when it kind of stuck then when it broke free the window dropped down inside the door panel. I need a diagrahm and instructions on how to remove door panel and what I am going to find inside. Thank you.
Old Dec 2, 2005 | 12:58 PM
buzzard's Avatar
buzzard
Door panel removal is easy.
1. Remove the "sail" panel at the top right of the door by prying it outward.
2. Pry off the decorative trim around the window/lock controls and around the door handle.
3. Pry off the light/reflector lens
4. Remove three screws (from areas you just removed trim) holding the door panel in place.
5. Give the door panel a sharp blow UPWARD to dislodge mounting clips. Disconnect any wires as needed.
Old Dec 3, 2005 | 03:12 PM
PaulC's Avatar
PaulC
You also have to remove the door handle, held in place by one bolt.
Old Dec 3, 2005 | 04:47 PM
WillieWildcat's Avatar
WillieWildcat
What year is your Expy? I have a diagram from Crutchfield I will post if need be.
