Transmission Linkage or Cable?
2001 F-150 4.2L Auto
180k miles
Sometimes shows in D but its really in 2.
Sometimes put in P, turn off truck, get out & starts to roll.
Get back in, step on brake. Go to start, wont crank. Take shifter from P to 1, then back to P. Then it wont roll & starts.
Sometimes Overdrive OFF light blinks & it only goes up to 3rd gear.
180k miles
Pay attention to the shifter positing by feel where you know it should be because the indicator may have a broken plastic part that moves the indicator.
If broken it won't show the correct position.
On the column down near the firewall the shifter has an arm that is bolted fast. See if it's come loose.
Good luck.
Good luck.
Be very careful about this.
The issue you describe sounds like control linkage or an indicator problems..
About these codes, what are they?
The transmission OD light would be on if there are any electrical malfunctions.
Did you consider the position indicator problem?
Did you check out the arm on the bottom of the steering column?
If not you can be set up for a frisking.
You came here for help now take it and do your part to help yourself..
Good luck.
Good luck.
RugerBob
04-13-2007 05:24 PM
