New member with question
I have a 2005 F-350 with 5.4 engine. The automatic transmission is giving most of the symptoms of the failed snap ring recall. My question is will a transmission from a 2004 f-350 6.0 diesel work in my truck. I believe both transmissions are 5r110w. The id tag on the 2005 gas tranny is 5c3p-7000-bb. The id tag on the 2004 diesel tranny is 4c3p-7000-kb. Any information is much appreciated
Welcome to FTE.
One of the guys here, Mark Kovalsky, is a former Ford automatic transmission engineer. If you repost your question with a thread title of "Will a diesel transmission work in my gasser?" or something like that, you may catch his interest.
Lots of good information to be learned here!
There is no shift pattern in the transmission. The shift pattern is in the computer, not the transmission.
There is one difference that will have to be addressed. The diesel torque converter has six studs, the gas version has four. Also, the stalls speeds are different. The diesel torque converter won't drive well in a gas truck if you can get it to fit.
So if you change the torque converter it will work.
epfire#233
Minnesota Chapter
21
03-09-2011 06:46 PM
idfergusson
04-23-2010 09:28 PM
