twin stick ?
I put a milemarker 203 conversion kit, New front lockout hubs, then faves my own twinstick setup. 2wheel 4 wheel on one stick, hi low on the other stock. Not the same as 20 5 twinstick. Front axle hi low on one stick, rear axle hi low on the otr.
No that is not correct.
On a 203 with 2 sticks the inside stick is hi/low and operates both front and rear. The outside stick is for 2wd or 4wd.
You can run the rear axle in hi or low OR run the front and rear in hi or low BUT you cannot independently switch between front only and rear only like a 205.
Its a chain driven case with a common shaft between the trans input and the yoke/output so the rear axle cannot be isolated.
No way, no how.
Just get a 205 + shifter from a donner truck and new lockouts.
The 203 + shifter are your week points. Also need the driveshafts from the donner truck. Swaping a 205 in gave me 1 or 2 MPGs. You can put the 205 in low range and do a good burnout with the hubs unlocked. I watched a guy twist his driveshaft off that way.
az45
05-16-2003 12:16 PM
