84 shift indicator linkage reassembly question
I had to reinstall the steering column in my 84 F250 that I didn't work on to begin with, and I'm 100% sure how the shift indicator setup gets put back together. I have the white tube/blue string that pulls the needle wrapped underneath the column to the slot where it gets screwed in, but I'm not sure how the loop at the end of the string attaches to shifter collar on the column. There isn't enough slack for it be connected and for the shift position indicator to be in the right place at the same time. Am I missing a part between where the screw goes and the loop in the string? The setup is visible by taking off the plastic collar just below the shifter collar. Thanks a lot.
Julie's77
08-27-2018 07:17 AM
Bulldawg1081
18
03-08-2013 07:17 PM
