Has anyone ever ran their exhaust pipe up, and in between the passenger door and the wheel well like a tractor. I just thought it would be fitting to the 300 to have a tractor looking exhaust with a flapper thingy. I just worry that it would be bad for my body panels.
You're going to have to cut into your body, then. Unless you've got something in mind that I'm missing. Do you have a photo that you can draw some arrows and circles on it and then share with us?
i think he means just running it along the side and then going straight up along the cab almost like a big rig. just runnning it straight up along the cab corner
That would make things easier, but he didn't say between which wheel well and the passenger door, so I assumed the front wheel because of the "tractor looking exhaust" (Which I assemed he meant a farm tractor). In any case, I'm sure he will clarify. On a side note, I've always liked how the Lil' Red Express Trucks looked!
Reason: Nit-picky grammar stuff.
I'm talking about the small area between the front wheel well and the passenger door. I am thinking if I turn the exhaust out right under the body panel there and then run it straight up from there.
