Temp Sender 1952 Ford 215cu Six
My 52 Ford F1 is running a 12v system. Has new gauges. I was not getting a temperature reading and realized I was still using the 6v coolant sending unit. Switched to a 12v sender. My gauge now reads 150 when cold and quickly pegs the gauge. The motor is not running hot. I saw similar thread with the 8 cylinder motor but no resolution. Would appreciate any help I can get with this. Thanks
You need to use your original 6v sender, and cut the voltage down that goes to it. Read some of these:
https://www.ford-trucks.com/forums/1...12v-truck.html
https://www.ford-trucks.com/forums/1...l#post11488132
https://www.ford-trucks.com/forums/9...-reducers.html
gt40racing
09-07-2009 10:53 AM
02GrayPowerStroke
01-14-2008 01:18 PM
